Control NI 9403 connect to srRIO 9631 by TCP-IP
Hi everyone!
I have a sbRIO 9631 board and NI 9403 on C series connector. I want to control a LED on NI 9403 by TCP-IP standard. So, how can i do it?
Thanks!
(2,973 Views)
Hi HCMUI,
A good place to start would be a couple of examples found in the LabVIEW example finder. The names of the VIs are TCP Communicator - Active.vi and TCP Communicator - Passive.vi. The example finder can be found in LabVIEW using the following path: Help >> Find Examples
Kareem W.
Web Product Manager
(2,962 Views)
