Multifunction DAQ
Creating spectral lines from a Color sensor to a DAQ
hi
I am trying to do spectral analysis of Intensity-wavelength. What I do to connect my RGB sensor to a myDAQ.
i just need to see the signal (DC-Voltage) output on my PC. The sensor has 20 mV - 1,5 V Output.
This sensor detect color change, so I can save the output to a text file using labview.
then i just want to calculate percentage intensity of light for any one wavelength in the source.
How can I use labview to do this analysis and make a real-time graph of Intensity on the Y axis and wavelength on the X axis ?
Also if someone has a VI which can explain me this it would be highly appreciated.
Thanks in advance for any suggesting.
(3,022 Views)
see same post:
http://forums.ni.com/t5/LabVIEW/spectral-lines-of-RGB-Color-sensor/m-p/1858987
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(2,997 Views)
