04-07-2008 08:13 PM
04-10-2008 11:56 PM
Hi Poli,
If you are following figure 4-12 on page 4-21 then you are connecting your signal correctly. As you can see from the figure, the load will be between the channel and the AOGnd. The AOGnd, AIGnd and DGnd are all connected. So you can connect your load between the DAC channels and pin 19, 20, 29 or 30 for ground.
I hope this helps,
04-11-2008 04:40 PM
04-11-2008 06:48 PM
04-15-2008 02:56 PM - edited 04-15-2008 02:58 PM
