DAQ Assistant error
I have just updated from LV 2009 SP1 to LV 2010. I am using a LV 32 bit on a 64 bit machine.
When I open DAQ Assistant, I get a pop up window that says "LabVIEW:  An exception occurred within the external code called by a Call Library Function Node.  this might have corrupted LabVIEW's memory.  Save any work to a new location and restart LabVIEW.  VI "Advanced Timing.vi:1" was stopped at node " " at a call to "DAQmxAssitant_DAQmx Get IO Control Info.vi".
If I hit okay, DAQ Assistant is locked up, if I use task manager to close the vi, LabVIEW crashes.
I have already re-installed DAQ device drive 9.5.1. with no success.
metzler CLAD
Message 1 of 17
(14,853 Views)
Accepted by metzler
There's no such version. The latest is 9.2.2.
Message 2 of 17
(14,842 Views)
I'm sorry, version 9.1.5.
metzler CLAD
Message 3 of 17
(14,828 Views)
I installed 9.2.2 and it works.
thanks.
metzler CLAD
Message 4 of 17
(14,826 Views)
I have had the identical problem but installing 9.2.2 hasn't fixed it.  Did you have to recreate code you had done when you were having the error or did it just work with the new version?
Dave B
Message 5 of 17
(14,648 Views)
The error did come up a couple of more times.  If my memory serves me, I replaced all of the DAQ assistant VIs with new ones, and have not experienced the problem since.
metzler CLAD
Message 6 of 17
(14,644 Views)
After months of wrestiling with this it turns out that there is s known issue with this.  Since I searched the forums and found nothing I want to post the response I received with the work around that way others can find it here if needed:
"The first option is, when you get that error, open up your task manager and
end the process, NiAsstnt.exe. You will get an unidentified error, but you
may be able to reopen the DAQ assistant and change what you need to change.
At the very least, you will still be able to access the rest of the VI
without shutting labview down.
The second, better, option is to open main_control.vi by itself, rather
than by opening your project. What I discovered today (which is how R&D was
able to identify this as a known issue) is that the error only occurs with
the project explorer open. I realize it is somewhat inconvenient to close
project explorer every time you want to edit the DAQ assistant, but that is
the best option I have for you until the bug is fixed."
I hope that this helps if someone else is looking for an answer to the same issue.  It seems that it is somewhat rare but can be a frustrating problem to try to solve.
Message 7 of 17
(14,591 Views)
FYI The VI he mentions there is my VI.
Basically, if you have this problem, your DAQ assistant will crash when you have the project window open.  Close the project and open the individual VI.
Message 8 of 17
(14,586 Views)
I'm not clear how you would edit a DAQ task or channel with the project explorer closed???
One way around this stupid problem: after closing the task or channel that causes DAQ Assistant to crash using the task manager, try opening a different task or channel that, hopefully, will not cause a crash. Then re-open the channel or task that crashed previously. It may not crash after succesfully opening another channel or task.
Message 9 of 17
(14,438 Views)
Mine was in a VI with Daq Assistants.  If I open the project, open the VI, then try to edit the Daq Assistant it crashed.  If I navigate to the folder where my VI is stored and open it only, I can edit it.
For a Daq task I'd guess you'd have to edit it in Max with the project closed then re-open the project.
I hope they find a fix for this soon.  It's inconvenient.
Message 10 of 17
(14,403 Views)
