DAQ assistant/ DAQMX task name issue
I have LabVIEW 2013. When I select a new DAQmx Task name and I right click -> New NI-DAQmx Task -> MAX... I get the 'Initializing' screen and after that LabVIEW freezes and I have to close it in the Task manager.
The same thing happens when I select the DAQ-assistant. The 'initializing' screen shows and after that it all freezes. I have the correct drivers installed and never had this problem in my previous LabVIEW version. (I recently switches to the 2013 version).
Can anyone help me with this? I could post screenshots if that can help.
(4,113 Views)
Dear Fatsat,
It sounds like during the installation of your software there has something go wrong and a component got corrupted. I have seen this issue once before and it was solved by repairing (or re-installing) the following two components:
NI System Configuration 5.5:
https://www.ni.com/en/support/downloads/drivers/download.system-configuration.html#307135
NI-DAQmx 9.8
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#288374
Could you try that and let me know if it solves you issue?
Rik Prins, CLA, CLED
Software Development Engineer
(4,092 Views)
