Multifunction DAQ
DAQ configure from Labview, aquisition from DLL
Hello ,
I am wondering if it possible to make configuration of  NI DAQ card from labview, but make data aquisition from DLL written in C++?
michael
_________________________________________________________________________________________________
LV 8.2 at Windows & Linux
(3,654 Views)
Hi Mishklyar
Generally when you create a task and configure it in LabVIEW you will have to use that task in LabVIEW. What you may want to do, is configure your tasks in Measurement & Automation Explorer, save them, and then access these task from your C++ code.
I hope that helps, let me know if you have any further questions.
Scott M.
Applications Engineer
(3,634 Views)
Thanks Scott,
I will think about it,but  will it work also with buffered analog output? ( everytime different data is loaded)
(3,595 Views)
Hi Mishklyar,
You can create Analog Output task in Measurement & Automation Explorer aswell, you can then use this task to out put different data, so long as you want to use the same output paramteres (Generation Mode, Rate, ect.).
Scott M.
(3,580 Views)
Accepted by mishklyar
Just an additional option:
If your task creation/configuration needs to be programmatic in LabVIEW, you can use the "Storage VIs" under Measurement I/O>>NI-DAQmx>>Advanced>>System Setup>>Storage to programmatically save a task.  Then from C++, you could just load that task.
Andy McRorie
NI R&D
(3,561 Views)
Thanks 🙂
(3,533 Views)
