Multifunction DAQ
DAQ in low pressure environments.
Does anyone know of suitable hardware (up to 100 analogue inputs) with LabVIEW
drivers, which can be used at simulated altitudes of up to 50,000 feet.
I was hopeing to use an SCXI 1100 or FiedPoint system but I understand these
are not suitable.
Ian Stokes
(3,203 Views)
NI Makes an AT-MIO-64E3 board that I have found to be very robust. We use it
in the oilfield industry aboard mobile units in Alaska. It is possible to
place two of these in the same machine that would give you 128 Analog ,
single ended input channels.
Question is, why would the circuit boards have to withstand the low
pressure? Why not isolate them, and just let your transducers take the
punishment.
Ian Stokes wrote in message
news:38be75d3@newsgroups.ni.com...
these
> are not suitable.
> Thanks
> Ian Stokes
(3,203 Views)
