DAQ product with +/- 12V analog output ?
We are looking to update a manual test box.
We are looking for a DAQ product with analog outputs capable of +/- 12V
We are not generating waveforms. Just using LabVIEW to set a voltage and adjust it in the range of -12V and +12V.
Does NI sell anything with this capability?
I have found the NI PCI-6703 and would serve our needs except that it is +/-10V.
(6,097 Views)
It would probably be less expensive to add an opamp with gain of 1.2 running from +/-15 V power supplies.
Lynn
(6,081 Views)
Accepted by nyc_(is_out_of_here)
Hello nyc,
Consider the PXIe-4322 or NI 9269. The PXIe-4322 supports +/-16V per channel. The NI 9269 has 4 (+/-10V) isolated channels which can be cascaded for greater voltages.
Izzy O.
Product Support Engineer
ni.com/support
(6,070 Views)
Lynn
True. We will have to seriously consider doing that since I know cost will be a big factor in the ultimate decision made by management.
(6,060 Views)
