Daq Repertory only in 8.2 and disapear in 7.1 8.0 8.2
After install of Labview 8.5 and MAX, my DAQ tradional disapear from Panel of LV7.1, 8.0,8.2 how can I retreive them ?
I know that this problem occured when update from 7.1 to 8.0 and after with new driver all was fixed but happened one more time with me and I do not find the paper on NI.com about this problem.
I need some help
Greg S.
CNRS
LV 7.1 8.2 8.6 2009 2011 2012 2013 2014
LPMC - CNRS
N'oubliez pas de complimenter cela fait toujours plaisir.
(3,496 Views)
Hello Gregory
I advice you to desinstall your Traditional DAQ and  install Traditional DAQ 7.4.4.  This can be found here.
Regards.
Romain D.
National Instruments France
(3,483 Views)
Merci,
J'ai utilisé une autre solution ( recopie d'une sauvegarde des différents repertoires DAQ utiles). J'avais déjà essayé la solution DAQ tradional 7.4.4 mais les VI DAQ n'apparaissaient aussi seulement dans la version 8.5.
Merci encore pour la réponse rapide.
Greg
Greg S.
CNRS
LPMC - CNRS
(3,480 Views)
Accepted by Greg_S.
That's fine you find the solution at your problem. Smiley Wink
Thanks for you reply .
Regards.
Romain D.
(3,477 Views)
