Daqmx 9.6 install error
I reinstall Windows XP. I downloaded NI-DAQmx to a fresh HDD. I get the following (attached)
How can fix it now?
Message 11 of 15
(1,434 Views)
Here's what I get when I try to repair (Error 1603):
Message 12 of 15
(1,432 Views)
Ok, I now tried un-installing DAQmx 9.4 and installing 9.2.2. I mind that 9.2.2 used to work just fine on this very hardware.
And I get problem with MIO again! What can be the problem?
Message 13 of 15
(1,417 Views)
Do you have a logfile from your clean install (two posts back)?  If you have that please post the log.  If not, please re-run the installer with logging enabled (see gaving's first post) and attach the log.
Message 14 of 15
(1,379 Views)
I gave up on trying to find the problem that MIO installer is running into.
What I decided to try is to install NI-DAQ as the 1st thing on a fresh XP SP image. It did work. I did install all the other drivers and patches after.
I wonder if the problem related to hardware driver updates which is particular for the given chipset (i945G), since other (different) machines didn't experience the problem.
Message 15 of 15
(1,335 Views)
