Difference between Software timing and hardware timing?
Hai
Anybody please say me the Difference between Software timing and hardware timing and it does?
(6,082 Views)
very shortly:
Software timing: Measurement is done in the way, that you use funnction in software to read/write, then the command is sent to the DAQ board, and then operation is performed - board starts AD/DA conversion, for example. It is usefull for slower applications, when you don't need precise timing
Hardware timing: DAQ board is timed by internal HW clock. It means, that all AD/DA conversions run based on hardware clock (very precise compared to software). Measurement is then put directly to buffer buffer, when you generate, you need to prepare data into buffer.
regards,
stefo
(6,070 Views)
thank u..
I still have some doubts..is it possible to generate pwm using PCI e 6320?
(6,060 Views)
