Unable to set BridgeCfg after channel creation using DAQmxSetAIBridgeCfg
I am unable to set the Bridge Configuration of NI 9219 device to any other configuration than the one specified during channel creation time. I am using the DAQmxSetAIBridgeCfg function.
The error that I get does not provide any hints to the issue:
    DAQmx Error: NI Platform Services:  A selector - usually of an enumerated type -
    is inappropriate or out of range. The operation could not be completed as speci
    fied.
    Channel Name: cDAQ2Mod2/ai0
    Task Name: _unnamedTask<0>
    Status Code: -50003
Please see the attached C-file that reproduces the issue. Note that I get the error message when I try to read the BridgeCfg after setting it to some value.
* OTHER DETAILS:
* Requires NI 9219 physical hardware.
* Does not reproduce with a simulated device.
* Reseting does not resolve issue.
* Running on 64 bit, Win7 platform.
* NIDAQmx Driver Version: 9.2.3f1.
Thanks!
Manisha Singh
The MathWorks
Message 1 of 10
(4,241 Views)
Hi Manisha,
This is strange indeed. I couldn't replicate the behavior in LabVIEW but I do see that error in CVI. I'll look into this and let you know when I have an update. In the meantime, you should just create your channel with the bridge configuration you plan to use.
Sean Ferguson
Application Engineering Specialist | RF and Reconfigurable Test
Message 2 of 10
(4,214 Views)
Hi Sean,
Thanks for looking into this.
Yes, my current workaround is to recreate the channel. Let me know if you need any other information.
Manisha
Message 3 of 10
(4,204 Views)
Hi there,
I face the same problem with you. When i choose the voltage, its work. But the pessure does not and showing me the error. Find the solution?
Lookin forward to Hearing from you.
Best Regards,
Voon Loong
Message 4 of 10
(4,143 Views)
Hi Voon,
There was a known issue found with NI-DAQmx 9.1 where the 9219 didn't properly support the new Bridge measurement types that would cause that error code.  This was fixed in NI-DAQmx 9.1.1.
I don't know of any reason why it would happen in NI-DAQmx 9.2.3; I'll investigate further.
Zach Hindes
NI R&D
Message 5 of 10
(4,133 Views)
I was able to reproduce the original reported issue in NI-DAQmx 9.3.  I have filed CAR 299983 to R&D to investigate and fix the issue.
Thanks for reporting this, and I apologize that this wasn't investigated fully the first time.
Zach Hindes
NI R&D
Message 6 of 10
(4,130 Views)
Someone beat me to it!  CAR 299887 was filed.
Zach Hindes
NI R&D
Message 7 of 10
(4,122 Views)
Hi Zach Hides,
Thanks for yor resopnce. Thats means I have to install ad upgrading to NI DAQmx 9.1.1.
Anyway, do appreciate.
Best Regards.
Voon Loong
Message 8 of 10
(4,118 Views)
Hi Zach ,
Thanks for providing the CAR number.
Manisha
The MathWorks
Message 9 of 10
(4,108 Views)
Can you do me a favor? I am doing on the pressure measurement using Labview. I have attached a file with regards to the procedure I did for your review. Can you check whether I am doing it correctly?
Your guidance is much appreciated.
Voon Loong
Message 10 of 10
(4,101 Views)
