02-20-2007 04:10 PM
02-21-2007 01:20 PM
02-23-2007 03:35 PM
02-26-2007 07:55 PM
02-27-2007 12:20 PM
02-27-2007 09:46 PM
What are you using (PXI, ETS, etc) as your RT target? Please
create a simple VI like in the attached picture and let me know if you receive
any errors. Please make sure to attach an error cluster from the DAQ assistants’
error out connector. I did not receive any errors when I ran the code in the
picture posted.
Also, can you please add error handling to your code and see if this results in
any different errors than the first one posted (-200477). The previous error
tells us "Specified operation cannot be performed when there are no
devices in the task", which leads me to believe that your 6229 may be a
different device number on your RT system than your Windows system. Although
your 6229 is called "Dev1" on your windows system, is it called the
same on your RT system?
02-28-2007 09:03 AM
03-01-2007 02:09 PM
03-01-2007 02:37 PM
