Multifunction DAQ
Disable track and hold PCI-6289
Hi all,
I use a PCI-6289, on connector 0, I connected a SCXI 1122.
I would like to use the connector 1.
In the M Series User Manual :
"When using Connector 1 in parallel mode with SCXI modules that support track and
hold, you must programmatically disable track and hold."
How can I do to disable track and hold?
(3,232 Views)
Not an expert on scxi, hope this helps
(3,210 Views)
Accepted by topic author fabpic59
Hi fabpic59,
That line from the manual only applies if connector 1 is connected directly to a second SCXI module, using a mode that the SCXI-1122 does not support, so don't worry about it.
To acquire from SC2Mod1/ai0 and Dev4/ai27 at the same time, add both channels to the same task:
18807i9A6CD27C0763B4A9
Brad
Brad Keryan
NI R&D
(3,186 Views)
