Multifunction DAQ
Disable track and hold PCI-6289
Hi all,
I use a PCI-6289, on connector 0, I connected a SCXI 1122.
I would like to use the connector 1.
In the M Series User Manual :
"When using Connector 1 in parallel mode with SCXI modules that support track and
hold, you must programmatically disable track and hold."
How can I do to disable track and hold?
(3,228 Views)
Not an expert on scxi, hope this helps
(3,206 Views)
Accepted by fabpic59
Hi fabpic59,
That line from the manual only applies if connector 1 is connected directly to a second SCXI module, using a mode that the SCXI-1122 does not support, so don't worry about it.
To acquire from SC2Mod1/ai0 and Dev4/ai27 at the same time, add both channels to the same task:
18807i9A6CD27C0763B4A9
Brad
Brad Keryan
NI R&D
(3,182 Views)
