‎10-29-2025 05:21 AM
Error '-2146893801' occurred when trying to create a unique temp directory path using the pattern
\\?\C:\Users\rathod2\AppData\Local\Temp\nipkg_preinstall-%%%%-%%%%-%%%%-%%%%-%%%%.
Error while installing NI DAQmx and NI package manager
‎10-29-2025 09:06 AM
What is the question?
‎10-29-2025 10:17 AM
How to solve installation error?
‎10-29-2025 12:31 PM
Maybe provide more detail first?
‎10-30-2025 03:14 AM
I am getting this error with all installers listed below with admin rights
NIPackageManager25.8.0_online, ni-daqmx_25.8.0_offline, ni-daqmx_25.8_online
I am using a Windows 11 PC with more than 30GB HD capacity available.
I had earlier installed NI Max using NI system configuration. But it did not have drivers to detect USB-6008.
So I tried installing NI DAQmx. This still did not resolve driver issue and I wanted to remove everything and install again. I used NI package manager to uninstall all and also deleted folders from C: drive manually after uninstallation. Cleaned registry of old installation using regedit as I was facing this problem. Looked and tried a lot of solutions suggested online, but nothing works.
