Error in building the application
    While executing a visual C application stored under "C:\Program Files\National Instruments\NI-DAQ\Examples\VisualC\Ai" i am getting a run time error stating that "The application failed to initialize properly (0xc0150002). Click on OK to terminate the application."
The hardware (6024E card) is installed in the PC along with the device driver having version NI-DAQ 6.92.
I even tried running the same application on the other PC having same hardware, but i am still getting the same error. What could be the reason for this type of error.
Please help me in sorting out this error.
Rakesh
(3,240 Views)
Accepted by rakeshc4
Why are you using traditional DAQ and why such an old version? The latest version is 7.4.4 and the current NI driver is DAQmx which is version 8.8.
(3,231 Views)
Hi Dennis,
               Thank you very much for the suggestion. It works now....
Rakesh
(3,212 Views)
