Error message 50152 when using PCI-6703
Hello, I just started in a lab using a PCI-6703. I have been assured that it was working before I arrived. However, it was installed on a computer running windows xp. We have installed it on an upgraded computer running windows 7 (no sp1). Device manager and NI-MAX can both see the board and it responds to being disabled and enabled through device manager. However whenever I attempt to run any test through NI-MAX I encounter error 50152. I have disconnected the cable leading into the board from outside the computer, so at this point there is only the board sitting in a pci slot. If I could get some advice on how to proceed that would be awesome.
(3,217 Views)
Accepted by topic author ajnmed
Looks like this may have been an error with the board. Turns out the lab had a replacement board ready to go. We switched it out for the one I posted about and I have no more errors.
(3,203 Views)
