Examples NOT working. How do I get streaming DAQ working with CVI?
I an trying to get CVI to talk to a PCI-MIO card. I would like to stream data from the card into a double buffer set-up to allow the DAQ to continue while displaying data. The on-line examples do NOT work.
Are there any working examples avaliable?
Information on what functions should be used and what other functions are required to set-up the card?
(2,521 Views)
Hello d_nobes,
Based on the information you provided, the following example might prove useful.
C:\Program Files\National Instruments\CVI70\samples\daq\Ai\DAQdoubleBuf
There are many more in the same folder.
I�m concerned that the example you tried to run did not work. Which example was it? The following information would also be helpful:
What version of CVI are you running?
What OS are you running?
What are your computer specs?
What version of DAQ are you running?
What PCI-MIO card do you have?
What drivers is it running?
What type of data are you streaming through it?
Have a nice day!
Robert M
Robert Mortensen
Software Engineer
(2,521 Views)
