sampling rate of DAQPad
How can I know the sampling rate of the DAQPad-MIO-16XE-50 and can I adjust it?
(2,441 Views)
The maximum sampling rate of the DAQPad-MIO-16XE-50 is guaranteed at 20 kS/s. The sampling rate is controlled programmatically; how to adjust the sampling rate depends on the environment you are programming in. You can specify sampling rate in Measurement and Automation Explorer for your device when creating a task or a channel.
For additional help see:
DAQPad-MIO-16XE-50 Manual
and do a search on 'sampling rate'.
Please post back with further questions. Be sure to include some helpful information such as development environment (LabVIEW, LabWindows/CVI, Traditional DAQ or DAQmx, etc�) Hope that helps!
Craig H.
(2,441 Views)
