Ext trigger ignored when generating pulses with counter
I am trying to generate a pulse (or pulse train) triggered by an external lo-to-hi transition of a digital line. I tried NI's example from genDigPulseTrainCont-DigStart.c, verbatim. Here is an excerpt of their code:
char triggerSource[] = "/Dev1/PFI9";
DAQmxErrChk (DAQmxBaseCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxBaseCreateCOPulseChanFreq(taskHandle,chan,"",DAQmx_Val_Hz,DAQmx_Val_Low,delay,freq,duty));
DAQmxErrChk (DAQmxBaseCfgDigEdgeStartTrig(taskHandle,triggerSource,DAQmx_Val_Rising));
DAQmxErrChk (DAQmxBaseCfgImplicitTiming(taskHandle,DAQmx_Val_ContSamps,1000));
DAQmxErrChk (DAQmxBaseStartTask(taskHandle));
I assumed that the last DAQmxBaseStartTask() call would arm the counter and make it wait for a rising edge on the PFI9 line before generating any pulses. Instead, the counter begins outputting pulses as soon as DAQmxBaseStartTask is called, ignoring any hardware triggers.
How do I configure a counter to generate pulses in response to an external TTL edge transition?
NI-DAQmx base v2.1 on Mac OSX, M6251 card.
Peter.
(3,732 Views)
Hello Peter,
Since you are using a shipping example provided with the driver, I would assume the code is correct.  I would make sure that the signal connected to PFI9 matches the specifications listed in the 6251 Specifications Sheet.  It is possible that the devices sees a trigger event and starts the task.  If you attach a ground signal to PFI9, does the counter output still start?
Browning G
FlexRIO R&D
(3,707 Views)
Dear Browning:
The PFI input is manually tied to bit0 of the digital output port on the same board, so I assume proper TTL levels everywhere.
Peter.
(3,700 Views)
Dear Browning:
Just to confirm, I tied the PFI9 line to DGND on my BNC-2110 breakout box, and I assure you that the call to DAQmxErrChk (DAQmxBaseStartTask(taskHandle)) in the above code example (taken verbatim from your genDigPulseTrainCont-DigStart.c example file) starts the pulse generator with no possibility of any edges occurring at PFI9. (why don't you try it at your end.)
So what now?
Peter.
(3,693 Views)
Hello Peter,
I have been able to reproduce your issue here on my end.  I will report this to R&D to find out why this behavior could be occurring.  I will let you know anything I find out.
Browning G
FlexRIO R&D
(3,672 Views)
Hello Peter,
This was reported to R&D (# 4HAGBSON) for further investigation. If you could provide me with some more details of what you are wanting to do, I could help you find a workaround.
Browning G
FlexRIO R&D
(3,650 Views)
