‎07-13-2006 03:42 PM
‎07-14-2006 01:59 AM
If we have to buy another DAQ (for example the PCI-6601), are there any problems/conflicts if we were to use two DAQs with the same PC?
No, you will not have any confilcts in such a setup
Plus, there is a little amibuity in the first part of your post.
Are you using the 2 analog output channels on board your PCI 6221 to generate the 60 Hz PWM signals and then counting them using 2 counter ??
hope this question answers your query!
regards
Dev
‎07-14-2006 03:52 PM
‎07-17-2006 01:32 AM
‎07-17-2006 03:29 PM
‎07-18-2006 12:20 AM - edited ‎07-18-2006 12:20 AM
Hi Vic,
Go to LabVIEW examples and search for 'correlated'
I am sure that the relevant example will show up in the search.
also, this link should be a good place to begin
Just for info, also read this
http://digital.ni.com/public.nsf/allkb/839CCB3E986542EB8625707C004E9F01
Regards
Dev
Message Edited by devchander on 07-18-2006 12:22 AM
