 Mr_Papagorgio
			Mr_Papagorgio
			03-18-2015 10:02 AM
I am using TPC-2215 and NI-9138. The VI running on the TPC communicates user inputs to the VI running on NI-9138. The VI running on NI-9138 generates a chart and displays it on the front panel in real time and I'd like to view the chart as its being generated. The problem is i cannot display the chart on the TPC because there is not enough room. I do not want to use scroll bars because the controls and chart have to be visible at all times.
Is there a way I can display the chart, thats being generated on the NI-9138 VI, on a separate monitor?
I tried connecting a monitor to the VGA port on NI-9138, but all that displays is CPU usage data, not the VI front panel.
 crossrulz
			crossrulz
			03-18-2015 01:56 PM
That tells me the 9138 is running LabVIEW RT. I'm thinking you will have to use another TPC-2215 to display your graph.
03-18-2015 02:20 PM
 crossrulz
			crossrulz
			03-18-2015 02:45 PM
You need to have another application that can read the data from the RT. So you will need another computer and monitor or just get another TPC.
 Dafex
			Dafex
			07-02-2016 09:52 PM
Would you share the section of your project where you get data from the NI-9138 to the TPC-2215? I tryed but something went wrong, the error message indicates that a task of DAQmx must be added and I added it on my code. .
