Home
Community
Discussion Forums
Most Active Hardware Boards
Multifunction DAQ
Topic
Multifunction DAQ
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How can I do signal analysis on an analog signal obtained by a Labjack DAQ
Foot
Member
04-08-2003
07:01 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I am using a Labjack DAQ to obtain an analog signal. All I get is a voltage signal. Is there anyway to convert this to a "time signal in" so that I can use other Labview vi's (such as "Extract Single Tone Information.vi") to do signal analysis?
0
Kudos
Message
1
of 2
(2,574 Views)
Reply
Re: How can I do signal analysis on an analog signal obtained by a Labjack DAQ
Ben
Knight of NI
04-09-2003
07:34 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I have not worked with Labjack DAQ hardware but I did visit their web-site some time ago.
First check with them about this question. What you need to find out is how determinsitic are the readings.
Without equally spaced (in time) samples, the extract single tone VI will not be able to help.
Ben
Retired Senior Automation Systems Architect with
Data Science Automation
LabVIEW Champion
Knight of NI
and
Prepper
LinkedIn Profile
YouTube Channel
0
Kudos
Message
2
of 2
(2,574 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
