Multifunction DAQ
How do I unreserve a DAQmx resource?
I am trying to use a Simulated AO Task.
It seems like I was able to sometimes get it to work, but now I can't even start a task. I get this:
Error -50103 occurred at PowerControl_DAQLoop - AOWrite.vi
Possible reason(s):
NI Platform Services: The specified resource is reserved. The operation could not be completed as specified.
Task Name: SimBufferedAO
Um... OK. So how does one go about "unreserving it"?
(3,445 Views)
Update: Closing LabVIEW worked.
Any idea what causes this condition? Anyone seen this before? Or know a better way to clear it?
(3,443 Views)
Are you stopping and clearing the DAQmx Task?
GCentral
(3,436 Views)
I don't want to clear it because I want to restart it later during the execution. So no, I am not clearing it.
Also, my understanding is that clearing the task is what you do when you've created teh task from scratch, and in this case I am using a task that is pre-defined for me in MAX.
Is this incorrect?
(3,405 Views)
You are going to have to supply some code so I can figure out your situation.  Otherwise I will just be grasping at straws.
GCentral
(3,400 Views)
