Multifunction DAQ
How do i set input limits for my PCI-6123
i am doing some 4 channel analog voltage measurement with a PXI 6123 card. In the attachement you will see an example. I want to change the input range for each channel separatly. But i don't know how to do that. It only works for all channels the same. Is it right that i can't do it for each channel separatly?
Jens
(3,383 Views)
Here is one of the ways of doing it
Any doubts, do ask
Dev
(3,379 Views)
Thank you very much! But i have only LabView Version 8.0 and the code you sent to me is in LabViw 8.2. So i can't open it...
(3,374 Views)
(3,356 Views)
