‎02-06-2008 01:35 AM
‎02-06-2008 05:07 PM
From my understanding, you would like to know how to calculate the signal to noise ratio (SNR) and effective number of bits (ENOB) since it is not found in the spec. I am assuming you are referring to the DSA and High speed digitizers. Here is a great knowledge base that explains how to SNR. As for ENOB, you will need to refer to this KB.
I hope this helps!
‎02-07-2008 02:13 AM
‎02-08-2008 11:46 AM
‎02-09-2008 08:32 AM
Thanks Chris!
ur reply is really helpful
But I still have two questions:
‎02-11-2008 03:13 PM
Does this mean that absolute accuracy doesn't affect SNR?
In the "Absolute Accuracy Table" the sensitivity is given, how it comes that it is less than the LSB?
‎02-12-2008 05:16 AM
Thank u Again 🙂
But please be patient with me because I still have two other questions
‎02-12-2008 10:54 AM
I understood from u that the quantization noise is already included in the rms noise entry in the accuracy table of 6221. Is that correct?
u said that we neglected the effect of nonlinearity on SNR. What shall we do if we want to consider it?
‎02-12-2008 12:09 PM
I am really grateful ![]()
