How to remotely manage DAQ tasks and SCXI modules?
Hi there, I have a system consists of a PCI4070, a PCI6024E, several SCXI1102 and a SCXI1130. I wonder if I can remotely view/create DAQ tasks and configure SCXI modules. My PC and the host PC of those devices are in the same LAN, I tried to create new in Remote Systems in MAX but it could not find any hardware. What should I do? Many thanks.
(3,256 Views)
Accepted by Barry Chen
Please be noticed:
A remote system(in MAX) denotes a real-time target that can be managed or configured over the network while a network device does not run a real-time operating system. Remote systems are not the same as network devices. A network device is any device that is accessible over an Ethernet or wireless connection. Such devices may be accessible by multiple computers and do not run a real-time operating system.
For your application, you can consider to use the VI server to run a VI to driver your devices.
http://digital.ni.com/public.nsf/allkb/0232C618DAA70F6C8625736200452C1D
无惧边界
(3,218 Views)
Thanks, I will investigate the VI server first.
(3,206 Views)
Hi Barry,
If you only need interactive access to the configuration (not programmatic access), you should also consider Remote Desktop Connection or VNC.
Brad
Brad Keryan
NI R&D
(3,201 Views)
