How to use DAQmx Start Trigger
I have to face signal acquisition/generation for the first time. I have to create a vi to acquire a signal while generating another one. The acquisition and the generation must be synchronous. I decided to use a trigger, but I haven't found a good example that could explain me how to use it. Can you give me some hints or, better, an example that could teach me how to proceed?
Thanks a lot!
(3,330 Views)
Open the Example Finder (Help -> Find Examples) and look through the examples in there. Attached is the location of the VI that should help you get started.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,326 Views)
Hi Lando,
the DAQmx examples indicated by Adnan are the best place where to start.
You can also consider this tutorial.
I hope it will help!
Bye!
Licia
(3,306 Views)
