Multifunction DAQ
Is it possible to save DAQmx test panel measurement values file?
I'd like to use DAQmx test panel for measurement purposes but measurement values must be stored to a file. Does DAQmx generate any log file of measured values or is there a way to get values?
(2,711 Views)
The test panels do not provide a means of saving the data. You need to have a program. Write one with what ever language you want or use the free LabVIEW SignalExpress that came with the device.
(2,693 Views)
