Issue with NI MAX crashing
Hello, i am having an issue with NI MAX. When i expand the device tree, my DAQ devices do not show (USB 6008 and PCI5922) and Max crashes.  I have attached the error logs and support ZIP.
I am runing an XP machine, Lavbiew 8.6.1 with DAQMx 8.9.5.
I have tried the reset configuration data but the issue is still present.
(3,494 Views)
You can try upgrading the version of your DAQmx driver and with it a new installation of MAX.  The latest version of DAQmx compatible with LabVIEW 8.6.1 is DAQmx 9.5.1.  This is the driver needed for the USB 6008.  If the PCI-5922 still does not appear after the upgrade verify that you have NI-Scope 3.0 or above and if the issue still persists with the digitizer you should post on this discussion forum.
Isaac S.
(3,470 Views)
DAQmx 9.5.1 can be found here.
Isaac S.
(3,469 Views)
Ok, thank you for your response, i will try a DAQMX 9.5.1 install.   I currently have MAX ver 5.3.3, is it possible to force an install of Max that is a previous version?
(3,460 Views)
Update:   I installed DAQmx 9.5.1 only with no Max install and everything works great now.   I can see my 6008/6009 devices and also the PCI5922 without NIMAX crashing.
Thank you!
(3,446 Views)
