LVDT and peak detector
hello,
i think i have done all the correct input,
but why there is no output appear on peak detector graph?
its only appear in LVDT graph,
when i try to display the peak detector using previous LVDT data, i appear with no error?
anyone could help me please?
thanks,
zull azym
research assistant
UTHM
Malaysia
(3,653 Views)
I took the main vi and cleaned it up a bit so that most of the code could be seen on one screen without scrolling.  I also added some extra indicators to probe the wires in order to get my head around the code.  I used Get Waveform Component to convert the waveform in to an array before the peak detection section of the code.  I was able to get the main vi to output like the peak plot vi.  Please let me know if you have any questions or concerns about what I have changed.  I hope this helps … if not please explain your application in further detail.
Samantha
(3,622 Views)
hello,
my labview version is lower version, 8.0
could u please sent me the example that i can open and view it, thanks
(3,613 Views)
Sorry about posting the wrong version.  The one attached to this post if for LabVIEW 8.0.
Samantha
(3,605 Views)
hello, thanks for the modified version. I have learn a lot and i am really thankful. I also can display and detect the peak value.
I then connect the signal trough the peak and valley threshold and then i got the answer says that two cluster with different content is appear.
I have tried a few ways but it seems like
i don't know how to fix it again.
this time i need to used this type programming so i can move the cursor when i stop measure. Then
i can manage the peak value by looking at the graph display.
i have attached the program that i have updated.
regards,
zull azym UTHM
(3,601 Views)
