Multifunction DAQ
Laptop hangs while using PCI-6132 and a magma box
I'm using a laptop along with a magmabox (Cardbus connection) to house a NI-PCI-6132 DAQ card. When I'm acquiring data the laptop occasionally hangs and must be restarted. Is anyone familiar with such a problem?
I haven't had this problem when the DAQ card is in a desktop with a regular PCI slot. So, I assume the problem is related to the magmabox.
Nick Wagner
(3,563 Views)
Accepted by nlwagner
Hi Nick,
The problem might very well be related to the magmabox, but before that can be determined, I need more information about your hardware.  I already know about the PCI-6132, but I don't know anything about your laptop computer or the magmabox cardbus connection.  Can you tell me the manufacturer and model number of both your laptop and the magmabox so I can check out their specs? Thanks.
Best wishes,
Wallace F.
Applications Engineer
(3,550 Views)
Thanks for the advice, Wallace.
We eventually solved this problem by uprading the magmabox cardbus interface to a expresscard interface after which the computer no longer would hang.
Nick
(3,430 Views)
