01-06-2007 05:57 PM
01-08-2007 01:55 PM
Hello Emilis,
The channel to channel skew in a 6111 should be very small. From your
post I assume that you are sampling up to 5MHz, not sampling a signal (i.e. a
sine wave) that is centered at 5MHz. What type of skew are you seeing
between the two channels? How are you determining this? Can you
attach a screenshot of a graph showing the two channels skew?
Since there is only one timing engine, both ADCs should be converting off the
same clock. I do not see how your Traditional DAQ calls could be causing
this skew. I do not think there should be a difference between DAQmx and Traditional
DAQ for channel to channel skew. However to make sure you are handling
arrays correctly you might want to take a look at a shipping example.
DAQmx shipping examples are typically installed C:\Program Files\National
Instruments\NI-DAQ\Examples\DAQmx ANSI C.
Finally, you mentioned that you are going to learn DAQmx. If you are
just starting an application I would highly recommend using DAQmx. All of
Jesse O.
Application Engineering
01-08-2007 03:02 PM
01-09-2007 10:14 AM
01-09-2007 01:00 PM
01-10-2007 01:59 PM
01-10-2007 04:01 PM
01-11-2007 01:33 AM
01-11-2007 01:41 PM
01-11-2007 02:18 PM
