Legacy DAQ and s-series 6111
Hello Emilis,
Hopefully this helps you out.  Please let us know how it works for you.
Jesse O.
Applications Engineering
Jesse O. | National Instruments R&D
Message 11 of 13
(990 Views)
Hi Jesse,
so, synchronous acquisition works. Actually, I wrote a short code in delphi and used op_scan function (instead of scan_start ) which was in Your C++ example. Simultaneous acquisition occurred even with initial daq 7 which comes with labview 7.
Interestingly, asynchronous acquisition function scan_start doesn't work in simultaneous regime neither in case of 7.0, nor in case of 7.5 daq. Again, I would not surprised if it is just my error (maybe I don’t know some peculiarities how use daq legacy functions) in coding, because when only one physical signal (sin) is connected (second input is open), I see two signals,- it is a nonsense.
Any way, I reached the goal.
Thank You very much for Your assistance,
Emilis.
Message 12 of 13
(978 Views)
Hello Emilis,
I'm glad your application is now up and running.  The code I posted was a modified shipping example.  There are other asynchronous examples that you could modify.  All C examples can typically be found here:  C:\Program Files\National Instruments\NI-DAQ\Examples\VisualC
These examples might help you out, if you want to see if there is a problem in your code.  If there is anything else we can do please let us know.  Again, if you are starting a new application I would recommend using DAQmx.
Have a great day,
Jesse O.
Message 13 of 13
(963 Views)
