License error trying to create task
When I try to create a new DAQmx task I get a message telling me that "this software is not currently licensed......etc...."
I'm using Visual Studio 2005,  DAQmx 7.3.0 and a fully licensed copy of Measurement Studio 8.01. for VS2005.
Is there a fix for this?  Do I need to install/reinstall something?
Curt
(3,966 Views)
Hi Curt,
Does the message say that the Measurement Studio or Visual Studio software is not currently licensed?
David
David
Digital Multimeters
(3,949 Views)
Hi Dave,
Thanks for the reply.  No. the licenses for MS and VS are ok.  One other thing
When I check the licenses for MS the DAQmx library isn't listed.  Should it be?
The following licensed Measurement Studio items have been installed.
Component:  Status:
NationalInstruments.Analysis.Enterprise  Licensed
NationalInstruments.Net  Licensed
NationalInstruments.NetworkVariable  Licensed
NationalInstruments.UI.WebForms  Licensed
NationalInstruments.UI.WindowsForms  Licensed
Curt
(3,924 Views)
Hi Curt,
Were you ever able to create a DAQmx task in this Measurement Studio environment?  Did you install the DAQmx driver after installing MS and VS?  If not, please reinstall the DAQmx driver.
David
David
Digital Multimeters
(3,911 Views)
Hi Dave,
After the reinstall, should "NationalInstruments.DAQmx" show up on my list of licensed libraries?
Right now I can't even set a reference to it in my projects
Curt
(3,904 Views)
Hi Curt,
Please try running the License Fixer attached at the bottom of this knowledge base and post a screepop of the results.  Thanks!
David
David
Digital Multimeters
(3,894 Views)
