03-05-2009 08:09 AM
When I try to create a new DAQmx task I get a message telling me that "this software is not currently licensed......etc...."
I'm using Visual Studio 2005, DAQmx 7.3.0 and a fully licensed copy of Measurement Studio 8.01. for VS2005.
Is there a fix for this? Do I need to install/reinstall something?
Curt
03-06-2009 11:52 AM
Hi Curt,
Does the message say that the Measurement Studio or Visual Studio software is not currently licensed?
David
Applications Engineer
03-09-2009 09:24 AM
Hi Dave,
Thanks for the reply. No. the licenses for MS and VS are ok. One other thing
When I check the licenses for MS the DAQmx library isn't listed. Should it be?
The following licensed Measurement Studio items have been installed.
Component: Status:
NationalInstruments.Analysis.Enterprise Licensed
NationalInstruments.Net Licensed
NationalInstruments.NetworkVariable Licensed
NationalInstruments.UI.WebForms Licensed
NationalInstruments.UI.WindowsForms Licensed
Curt
03-10-2009 11:53 AM
Hi Curt,
Were you ever able to create a DAQmx task in this Measurement Studio environment? Did you install the DAQmx driver after installing MS and VS? If not, please reinstall the DAQmx driver.
David
03-10-2009 04:07 PM
Hi Dave,
After the reinstall, should "NationalInstruments.DAQmx" show up on my list of licensed libraries?
Right now I can't even set a reference to it in my projects
Curt
03-11-2009
02:35 PM
- last edited on
09-21-2026
05:41 PM
by
Content Cleaner
Hi Curt,
Please try running the License Fixer attached at the bottom of this knowledge base [link removed; article no longer available] and post a screepop of the results. Thanks!
David
