i'm using an scxi 1303,plugged into an scxi 1100, and am using it to read in the output of a load cell (and many pressure transducers). the output of the load cell (2mV/V, 12V bias) is measured across the pins in the 1303 with a multimeter, and is as expected, but the virtual channel test panel is reading about 5 volts, regardless of any load application. everything else on the 1303 works fine. am i using the wrong terminal block for this measurement? please advise.
