MAX 4.3 and VISA 4.2
When I install VISA 4.2 and MAX 4.3, I get the following message:
there was a problem connecting to the database
I try different things but I did not get the clue.
VISA 4.2 without NI-DAQ mx 8.6 (and MAX) is OK
DAQ mx8.6 and MAX 4.3 is OK, but as soon that I install VISA 4.2, I get this error message
Thank for your help
Patrick Dupre
University of York
pd520@york.ac.uk
(3,426 Views)
Hi Patrick,
There is a good Knowledgebase article which describes several different causes and solutions:
http://digital.ni.com/public.nsf/allkb/B9107A7F281F9B408625720B0078E5A8?OpenDocument
Let me know is this helps.
Regards
Jon B
NI UK & Ireland
(3,414 Views)
As I said in my email, I played around a lot before I sent my email.
Right now, it is working without the VISA server. I do not really why. I replaced the config3.mxs file
Did you try to install on the same machine NI-DAQ mx8.6 (including MAX 4.3) and VISA 4.2 ?
Regards
(3,408 Views)
Hi Patrick,
DAQmx 8.6 and VISA 4.2 (MAX 4.3) are the versions installed from the third quarted device driver CD's so myself and most of my colleagues have these versions. Where are you installing NI VISA from?
Did you restore the config3.mxs file from the backup or completely delete the data directory?
Regards
Jon B
NI UK & Ireland
(3,392 Views)
Hello Jon,
Both have been downloaded from your web site
Regards
(3,383 Views)
