Magma expansion performance with NI PCI 6534
I want to use the Magma PCI expansion with a NI-6534 DIO card. I need 16 bits transfer from 2 MBytes/s up to 20 MBytes/s (1Mhz to 10Mhz).
Will the PCMCIA card between Magma card and the laptop slow down the transmission?
(2,743 Views)
To give a correct answer I would need to know your exact configuration :
Which Magma PCI expansion do you want to use ?
Could you explain with more details the different connexions?
regards
Marc Larue
NIF
(2,704 Views)
