Measure propagation delay throught unit under test
 I need to measure the time delay between a digital enable signal being applied to the board under test and the output(s) being enabled.
The digital logic is generated by usb6218 using daqmx.
The analogue output of the board under test is measured by a usb5133 scope card. I have spare analogue inputs on my 6218 if this sort of timing can only be done on one piece of hardware. I prefer to use the 5133 because this is required for measuring the rise time of the signal.
Ideally I would also like to plot these two signals on a single graph.
Message 1 of 1
(2,817 Views)
