Multifunction DAQ
Measuring resistance of PT-100
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(4,356 Views)
Accepted by MogaRaghu
Hi Raghunathan,
You may find the following links of help:
Taking Temperature Measurements with RTDs: How-To Guide
Measuring Temperature with an RTD or Thermistor
Also, it would help if you elaborate your requirement a bit more whenever you post.
(4,346 Views)
Raghunathan
(4,330 Views)
Hi NavS,
thanks for your reply.
It was really helpful to read through the links that you had given and i now think the solution is at hand.
Incidentally there was a problem with the forum posts ever since I switched to IE9. Reason why you did not see my post and only the subject line appeared. I for one, would never dream of such a brief post with only the subject line !!  Anyway after I switched on Comaptibilty view in IE9, things have become normal ( as you can now read my message !)
Raghunathan
(4,310 Views)
