Multifunction DAQ
NI 9625 compactDAQ/compactRIO compatibility??
      The question i want to ask is that whether NI 9265 (analog current output module) is compatible with
      compactDAQ or not.
      The comparison tables shown in the attached pdf files, "NI-Datasheet-ds-219.pdf" says no compatibility
      for compactDAQ.
      And in the other pdf "NI-Datasheet-ds-220.pdf" says compatibility "yes".
      Which one is correct?
      Waiting for urgent reply...... Thanks
(3,309 Views)
Accepted by Waqar123
Hi Waqar123,
I am sorry about the confusion.  According to the documentation below, the NI 9265 is compatible with the CompactDAQ and CompactRIO.
https://www.ni.com/en/support/documentation/supplemental/08/c-series-module-and-compactdaq-compactri...
Also, on the product page linked below, under specifications it is listed as both CompactDAQ and CompactRIO Form Factor.
https://www.ni.com/en-us/shop/model/ni-9265.html
The 9265 is compatible with with both CompactRIO and CompactDAQ.  It seems that the NI Datasheet ds 219.pdf which you linked in your post is incorrect and I will work on having that fixed.  Thank you for bringing this to our attention.
Andrew T.
(3,282 Views)
