NI 9862 CAN configuration in matlab/simulink
I have a problem with the NI 9862 CAN module. I want to use matlab to comunicate with the CAN port, however when I try to configurate the CAN device, MATLAB crashed.
I use the Module with the NI cDAQ 9178. I installed the Vehicle Network Toolbox Support Package for National Instruments NI-XNET CAN Devices.
(1,351 Views)
I would recommend you try the NI-XNET Bus Monitor first. If the Bus Monitor works, the NI-XNET driver is working properly. You will have to reach out to Mathworks technical support for the assistance on the Vehicle Network Toolbox Support Package.
https://tmesystems.net/
(1,325 Views)
I don't have problems with LabView and it also works with the Bus Monitor.
But thanks for the answer, I try to reach the technical support.
(1,310 Views)
