NI USB 8452 2xSPI+I2C
I have USB-8452 controller and want to controller one chip with two CS line and one external ic working on I2C bus.
How can I configure both CS line at the start + I2C bus and acquire one SPI line together with I2C bus on same time.
Example is nice.
S
(2,042 Views)
Unfortunately, there is no way to synchronize both SPI and I2C, though you can use them independently but you cannot say/guarantee that both occurred at the same time.
Could you please provide more information on the devices and application requirements to see if there are any alternatives?
Santhosh
Soliton Technologies
(2,026 Views)
Thank you for reply.
Ok, I do not need "true" synchronisation.  It is enough that they are configured at beginning and started one by one in a while loop. I would like to avoid closing task completely and making new with SPI and again new with I2C.
I'm making a test setup to read two chips with SPI and one with I2C interface (ADC for T[°]) so that I can characterize my DUT.
S
(2,023 Views)
Accepted by Dimsasko
Yeah, that is possible. You can create the configuration once and use it in the loop without closing.
Santhosh
(2,019 Views)
