- I use NI9219 to capture the temperature(3 wire RTD mode), with the same configuration on 4 channels, as a result I get different values from each channel.
The difference between MAX and MIN is larger than 2 deg C. Why ?
- I get the 3 wire RTD sensor in my hand, but I don't know if it is pt100 or pt1000 or anything else. The NI part number is :745691-02
I configure it as pt3750 in "RTD Type" item during my test.
