Need NI Card for Simulink
For controlling a slow system, I have to read in 2 analog Signals and also get out 2 analog signals. The signal range must be up to 10 V. The card also must have an USB port and should be programmed with MATLAB Simulink.
I think the NI-USB 6008, 6009 or 6211 should work, but I read posts from users having problems. Could someone give me a positive feedback, before I buy a card?
(2,969 Views)
Hi There,
you can use any hardware which is supported by the drivers here:
http://www.mathworks.com/products/daq/supportedio14005.html
So generally any of the cards you mentioned should work.
Hope this helps, RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(2,953 Views)
