Multifunction DAQ
Need help with high voltage controling
Hi apok,
Thanks a lot, the code that you post to me already works. Now I need to add more functions, like the voltage can increase to 20kV in a certain of time.
Message 11 of 15
(1,208 Views)
@Kyle-Z wrote:
Hi @apok,
great! please give kudos to those who have help and marked solutions that solves your questions...   Smiley Wink
Message 12 of 15
(1,203 Views)
@Kyle-Z wrote:
...The goal is to fully control the high voltage. For example, the DC voltage can chang from zero to 30kV in 5 or 10 seconds, and be stable at 30kV at 30 minutes, and then come down smoothly to 20 kV in 5 minutes and finally come back to zero. Could someone help me with this task? Thanks.
check here to get you in the right direction....
Message 13 of 15
(1,196 Views)
Sure, thanks again. If I have trouble with this program, I may post another one.
Message 14 of 15
(1,190 Views)
Message 15 of 15
(1,177 Views)
