Ni-6120 - Real sample rate resolution
Hello.
I'm using the NI-6120 card and labview 8.2.
And I didn't find any informations about the sample rate resolution.
So I wonder if someone know what is this resolution ?
And can I get the real value of the sample rate of the card after I have programmed the sample rate I want.
Thank you!
Sincerely,
Romain
(3,345 Views)
Accepted by romainv28
Hi Romain,
Refering to the datasheet the sampling rate for a PCI/PXI 6120 is 800 kS/s with NI-DAQmx divers.
If you want to get the Actual Sample Rate with LabView and DAQmx drivers use a Timing Property node and select Sample Clock>>Rate.
Ludovic R.
links:
NI-6120 DataSheet
(3,330 Views)
Ok, it's what I was looking for!
Thank you !
(3,318 Views)
Furthermore, the internal sample clocks are derived by dividing-down a 20 MHz oscillator.  So you can only achieve integer divide-downs of 20 MHz.  Sample rates on analog input tasks are always coerced up if you specify a rate that cannot be achieved by an integer divide-down 20 MHz.  You can read this coerced rate through the property node like Ludovic mentioned.
Best Regards,
John Passiak
(3,308 Views)
