I am using an NI USB-6251 multifunction DAQ. The self test passes, but when I run test panels I do not get any analog output or input. This worked fine about 1 month ago when it first arrived, but now that we are going to use it, it no longer works. I have wired AO0 to AI0 and in test panels I used sinewave generation from the analog output with AO0 selected and then used continuous sampling mode in analog input with AI0 selected, but instead of the sinewave it is just a continuous value of -0.00866. I have tested the cables and tried every combination of channels and options on the test panels.
Please let me know if I am missing something,
Hannah
